L
lazy-riders
Hi, I have a job where I need to get a 10mm single phase cable from farm house (not a working farm) to outbuilding for a solar pv installation. Client adamant he does not want cable in a trench and wants it overhead from gable end to gable end.
The distance is 22m, was thinking 10mm split concentric would be best option, but have never spanned a cable this size over this distance.
Any advice would be appreciated, is it feasible, i.e using centenary wire, any hints or tips.
Thank you.
split con. on a catenary would be OK, bearing in mind the height restrictions ( pedestrian or vehicles), are your calcs. worked out right? your catenary fixings would have to be sound for that sort of cable weight also.
Thanks for the replies, pull out force was a concern, figure constructing a uni strut bracket and resin fixings at farm house. Outbuilding is timber
