Some things like resistance are easy to check with a box with a few known resistors (high value and low value) and in most cases you are checking for "is it broken?" which is a whole lot cheaper and easier than a specific check such as "is it 0.1% or 0.5% accurate?". I remember one of the guides once said to do that regularly.
But some other things are much harder to check without specialised equipment, such as the RCD trip testing, but I guess if the main instrument is still reading resistance OK it is likely to still work. Even then if you have a known RCD at home/work then you could periodically check it is acting the same way to look for change if not absolute accuracy.
[automerge]1587063109[/automerge]
I see Megger make a test kit for around the same price as a entry level MFT:
www.tester.co.uk
If you have several at your company it might be cheaper to buy one and do your own checks (even offering it to others for a small fee).
Megger MTB7671 Calibration Test Box
The Megger Test Box is an essential purchase for testing your equipment, providing readings that conform to British Standards.
