C
CNC
Hi
I am still fairly new to PAT and have tested a couple of the sites for the company I work for and now doing the big sites for the holiday (schools and residential sites etc...). But with all the testing I have done I have noticed with a fair number of kitchen appliances (only freezers and fridges) are starting to cause sparks, while I failed the first 2 I noticed the number of these appliances are causing sparks to be to high then it should be but all past fridges and freezers I have passed just fine before to make me doubt its the Portable Appliance Tester.
Its just the numbers don't really add up with each other just to many are having sparks but the tester has proven that it can pass these appliances fine.
So could it be me at fault in the settings, possibly the probe or can it be the tester?
I am using the KT71
I use the Setting of "Class 1 20Amp" I have also checked to see if the plugs hold a 13Amp fuse and they all do and I was told that was the setting to use with 13 Amp fuses for more accurate readings. Using the "IT 200mA" setting constantly caused the items to fail and just doesn't have accuracy to what the actual earth test value should be.
Looking forward to hearing from you and thank you
if you're getting sparks when performing earth continuity @ 20A, then it's usually a poor contact with the earth lead.
lol....lol...
so i see someone struggles with the concept of connecting a croc and pressing a buton now...
lol...
The company tester had a fairly beaten up probe and dident come with a crocodile clip so either the probe has this earthing issue or possibly my fault for placing the probe wrongly...but I see that not overly likely in that I have tested some of the appliances a fair few times and constantly sparks or failed result each in different places and the probe was firmly placed tip first. Thanks Telectrix and Oldtimer
