G
G.Tate
Hi,
Iam looking at PATesters and would like any feedback on the Seawood Apollo 600 is it as easy to use as stated in the sales talk.
Horse for courses I do pat in rentals is 10-12 items so kewtech kt71 fits the bill but on big jobs doing it day in day out then the 600 could be the one
Hi G.Tate,
I think oldtimer is right; "Horses for courses". If you are doing higher volumes of PAT testing then you obviously would benefit from a tester that is more comprehensive with a QWERTY keyboard inbuilt.
I have personally spent quite a bit of time now using the Seaward Apollo 600 as it is, for us, quite an exciting tester and new to the market. My feedback would be as follows:
General use of the tester is actually quite straight forward and even easier if you have used a downloadable PAT in the past. Some of the symbols above the "F" keys can be difficult to decipher as symbols are used rather than text, but this is very quickly overcome once you start using the tester.
The PAT Testing facility itself is very quick. Using Auto-Test sequences the user instructs the tester what type of appliance is being tested (ie. Class 1 portable, Class 2, Surge Protected Extension Lead etc etc) and the tester will run the necessery tests required for that type of appliance. This process works really well and is quick and easy.
The general ergonomics of the tester are brilliant and I think it is currently the best on the market. The tester is very portable and weighs around 2 pounds with a colour screen and a good QWERTY keyboard inbuilt for appliance data entry. This is a massive step up from the Primetest 350 predecessor which has an ABCD.... layout which was difficult to get used to. Ergonomics are great and is really a massive benefit when using in the field where it is often a lot easier bringing the tester to the appliances as supposed to the other way around. Portability and battery powered really makes things a lot easier in many working environments.
The Apollo 600 also has other features built in such as a risk assessment calculator (based on the IEE recommeded test frequencies), Fire Alarm and Emergency Lighting Forms and a Digital camera which can be used to tag images of appliances or potential dangers/faults to the assett and onto the test report.
These extra features might benefit you and then again might not. Some of our customer has seen great potential in these while others choose to use the PAT functions only.
The extra features built into the Apollo 600 work fine. However, the interface with the risk assesment calculator could be slightly improved in my opinion as the text is rather small. Purely considering the PAT functions within the Apollo 600 I still think it is the best tester on the PAT market at the moment. This is due to its size and ergonomics, speed of testing and general specifications and storage capacity of the tester.
Seaward are also continuously improving its interface by listening to feedback and updating the firmware.
If you wish, you are welcome to come to our premises in Leeds for a more thorough demo as I can see that you are not too far away from us.
Hope this helps
Lasse
Test-Meter
