Discuss PEB to external tap on outbuilding in the UK Electrical Forum area at ElectriciansForums.net
Sb8389
Hi guys,
Went to look at a job today where they are wanting power installing into an outbuilding. The outbuildings consist of an outside toilet and a store room. I noticed they also had a outside tap. The water is bonded in 10mm inside the house and the water supply to the outbuilding is installed underground in copper. Would i need to bond the outside Water tap in 10mm aswell.
If you need to know anything I have not covered just ask
Hi guys,
Is it a remote outbuilding?
Is the water pipe in the outbuilding connected to the house water pipe i.e. Is it from a common supply and not 2 separate water supplies?
then it's already bonded via the copper pipe. easy check is to get your wander lead out and measure the resistance to the MET and to the main water bond in the house.
Defiantly worth testing the part in question.. even if the main water supply were plastic and not requiring bonding this copper pipe thats buried would be extraneous and creating a earth fault path even though main incomer is plastic, similar to some houses where heating pipes are buried in the floor. Get the test leads out, & well spotted.
Reply to PEB to external tap on outbuilding in the UK Electrical Forum area at ElectriciansForums.net
Hello, Carrying out remedial work on a commercial site and I've come across a metal out building that has a water supply to it. The water pipe...
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
Hi all, I have a log cabin in my garden. An electrician ran an armoured cable from my consumer unit to the log cabin and this terminates on the...
Just thoughts Id share my recent fun and games on my parents farm.. The electrics are old. Its a 400yr old house with outbuildings just as old...
A 'Sunday challenge' for the qualified electricians.... Can anyone explain why a built-in gas meter housing box that is located 600mm above a...
6K
