- Reaction score
- 2,833
Hi all. I'm after some practical advice please.
Got a job to quote for, fitting a couple of gimbal downlights in a sloping ceiling in an attic room. The construction appears to be PIR (celotex or similar) insulation between rafters, with plasterboard faced PIR insulation over the rafters, skimmed over. I'm expecting to have to cut out a slab of p-board and insulation at each downlight position, remove enough insulation behind to make room for the downlight, then fix the slab back in place, and make good.
How would I fix such a slab soundly back in place, ready for filling and sanding?
I was thinking when cutting it out, to angle the cuts inwards so the sides are tapered. Then to fix it, use a generous amount of polyurethane glue eg. gorilla glue on the sides and back, push it back in place, and hold it there with battens while the glue sets.
But perhaps you guys and girls know a better way of doing it?
