The capacity of the battery will not be too much, as the inverter will take what is needed - it can't 'force more in'. Daz
I wouldn't have thought it would have any settings if it's just a bog standard off the shelf inverter. Daz
If the inverter is connected using a cigarette lighter plug then the cheap ones are not rated for over 3A current and the internal "wiring" will overheat and melt the plug.
However if the plug came with the inverter I would expect it should be OK.
I have melted cigar lighter plugs running a 12V 4A fridge.
You just need a more robust connector.
Inverters and laptops don`t mix.....simply because the inverter is not pure mains onto a switch mode power supply, you will need a pure sign wave to work, and even then its trial and error.
