K
Knobhead
I know some countries use protection to guard against a broken neutral in PME systems.
Anyone know how they work?
Discuss PME & Broken neutral in the Electrical Forum area at ElectriciansForums.net
Acording to E54 it never happens, so why bother.I know some countries use protection to guard against a broken neutral in PME systems.
Speak to the DNO ask them if you can fit an Earth Rod as a back up they will probably say no but do it anyway lol
J
Most of the underground PME joints to supply buildings are staked by the dnoThat is the way it is done in some countries an external electrode is connected to the N / E juncture within the service head.
I don't quite get where he's saying it should be positioned in relation to it's effectiveness ? My CU has a 30mA non delayed RCD as a main switch will it trip out if the N drops out ? it's the same as his diagram isn't it ?
J
Doesn't the white wire on the RCD help with this?
It happened to my house years back.
I am thinking if 10 houses are on the same phase as me and the N drops off will I get all their fault load as well because my nice shiny new earth rod will provide a lower path of resistance than all their bonded extraneous water and gas ?
Reply to PME & Broken neutral in the Electrical Forum area at ElectriciansForums.net
