To be fair PME faults are not very common, and the real risk is for stuff that people are likely to be in good contact with while also outside. Electric cars being washed while on charge are an obvious risk, metal caravans on nice wet grass, boats on marinas being fed power while engines off, etc.All this has also got me thinking about my outside lights, I have 2 class I each side of my front door at about shoulder height. That is probably not a good idea being PME hahaha
I guess most outdoor power or gardening tools these days are double insulated so no earth to worry about.
Thought there was a school fence that gave some kids shocks (thankfully none fatal) in the news not that long ago, so it is not unknown!
[automerge]1586604142[/automerge]
Is the sub-CU fed from the main one, or split meter tails?I have a memera 2000 split C/U. However I do have RCD protection on all circuits, I have a sub C/U for electric shower containing RCD, and down stream RCDs for lighting circuits.
If fed from the main one, is the main switch one that could simply be replaced with an RCD?
A quick search found this 2nd hand one, the earth tail is cut short but it might just be worth a try if you have a MFT to check the trip characteristics, etc, on some simple test bed before deciding if it could be fitted:
