Discuss porsche 911/996 light and cluster problem in the Auto Electrician Forum area at ElectriciansForums.net
Hi,Got Carrera 4 year 2000.The car was in sea transit so likely battery was jump started. I found that right front headlamp not working at all ,no indicators, no lights and also cluster all backlight not
working as well(can not see current mileage)Remote key does not working too. Checked fuses, they
seems to me all ok,Do you think it could be a faulty light switch , headlight control unit ecu, or bad connection??Please help with advice, thanks
Reply to porsche 911/996 light and cluster problem in the Auto Electrician Forum area at ElectriciansForums.net
Hello I have a problem with my 2010 Kia Sorento kx2. I recently bought a second hand trailer. I was told all the lights were working so I plugged...
Mileage: 112223 - DTCs - P0480 cooling fan. Also codes in TIPM P0691, P0692 for cooling fan control circuit. Tests/Procedures Performed: 1...
Has anyone taken apart their & self repaired it? 2013 Dodge Grand Caravan SXT - Mileage: 112223 - DTCs - P0480 cooling fan. Also codes in TIPM...
The symptoms its been having to start with was the fuel gage only working sometimes and when i play music from my phone when a loud song came on...
Hi all, I have an issue with my brake lights coming on when I take the key out the ignition. Therefore running the battery down. The brake...
