R
ravihara
Hi! im from Sri Lanka and I'm a user of a 860W graphic workstation and our home electricity circuit is having a Power fluctuation problem because of a nearby welding shop. This makes My UPS corrects This Power fluctuation good 30- 40 times per minute (thus 4-5 hours a day) and this causes every UPS i buy to die after one or two weeks! So what I need is some sort of a reliable and stable some sort of a unit/equipment between my UPS and the power socket that is durable and can handle and correct this kind of Power fluctuation problem thus will give my UPS a neat electricity supply, so it is free from correcting this Power fluctuation problem itself. need expert advice asap.
thanks a lot for your time.
If the problem is overvoltage then a surge protection device may be the way to go,however if undervoltage is the problem then talk to your electricity supplier as the welding shop may be pulling more power than the supply can handle,dont know what your suppliers are like but in uk they jump all over you if you start causing problems that affect other users.
the problem is under voltage. here the services are very poor. one can do anything if they bribe the correct hands. :( I contacted the electricity board more than hundred times but no use. that is why I thought of having a solution from my end. any thoughts of solving it from my end?
Are the UPS units just the right size for the job or oversized to give some leeway? For use on a steel works where we had similar problems I installed a UPS twice the required size and also fitted a piggyback battery pack.
You could consider a Buck-Boost transformer to take out short-term dips caused by the welders striking an arc. They wont take out long-term dips. You will need to source one locally. They cost about £250 in the UK.
Without any figures for the voltage it’s hard to give other possible solutions. If you can get a local electrician to take readings it would be helpful.
How about a fairly 'dirty' rectifier to get to something resembling DC, and then an inverter back up to 230 (then on to the UPS etc)? I know that's kind of what happens inside a UPS anyway, but a dip down on the DC side for an inverter isn't going to be that big a deal (just think what happens on a PV panel). Or am I a mad man?
Damn good idea. Charge a couple of leisure batteries to make up any short fall.
A UPS without the bypass.
:34: Outside the box.
:whatchutalkingabout sorry guys, can some one simplify me the solution a bit? what equipment do i need? some local electrician told me that i can use a power inverter.. is this the same solution?
edit: and the solution must be only from my side. cause no use of talking to that welder or damn electricity board. :/
I read a bit about it and now i got it! (i think) I use a rectifier to turn my AC power to DC and then power an inverter using it and get a perfect AC wave. (is it guys?) and i searched ebay for a rectifier but seems like selecting a one is out of my knowledge. can someone please point me out the correct and powerful enough rectifier and an inverter in ebay for me?
A battery charger feeding two caravan leisure batteries. Run the inverter off them.
The charger will keep the batteries continuously toped up. The inverter will draw a steady power of them.
Oh! got it now! is there a alternative solution for caravan leisure batteries? cause it will cost me about 200$. and my total budget is like that.
