K
Knobhead
As Phil has said, you will be relying on them. How much does having to buy new UPS units cost.
ya. great point. I decided to go with it! so where can i find a unit to charge 2 car batteries and get charge out of them same time? sorry for so many questions. I'm n00b to these kind of equipment.As Phil has said, you will be relying on them. How much does having to buy new UPS units cost.
because you are asking for a reliable source of supply,if the outlay to do the job properly is too much then maybe you should just stick to replacing your present set up every so often and see how it works out cost wise over a year,sorry if this sounds harsh but you asked for a solution and we gave you the cheapest but even that seems too expensive.why are 2 batterys required? maybye use one big one (12 volt) it might be cheaper
