Discuss Primaflow circulating pump failure? in the Central Heating Systems area at ElectriciansForums.net
Green1
I have had a single instance of a Primaflow GPA25-6-130 circulating pump 'locking up'. This is a CPE series unit, with Auto function: it's 3 years old. The AC mains supply was present, all the display elements were lit (abnormal) and the pump wasn't running. There was no response to pressing the Mode switch. After switching the system off for about 5s and then restoring the mains supply, normal & full operation was restored: there have been no more glitches after 2 days running. I'd be interested to hear if anyone has had this or a similar issue with this pump type: thanks.
Reply to Primaflow circulating pump failure? in the Central Heating Systems area at ElectriciansForums.net
I have an electric oven - now many years old. I have replaced the main circular 2.5kW oven element (ELEHY6708) several times over the years...
Hi, I’m trying to find a frost stat that will facilitate the switch off of mains power 230VAC to both a fish pond pump & UV clarifier (combined...
Hi, I hope that someone here might be able to put my mind at rest. I have an engineering mind and a reasonable understanding of electical work...
Evening All, Strange one so after a bit of advice. Got called to a customer this evening who had their boiler repaired after the circuit board...
Need some help please. Got a brain teaser for my first post. My pool pump motor cratered over 4th of July. It was working fine and started to...
