Discuss Problem with my hobs = ( in the UK Electrical Forum area at ElectriciansForums.net
Holyhead, north wales
if its an induction hob have you tried switching it off and counting to 10 then switching it back on , they can be a right pain some times , if you would like me to pop over send me your address and contact details i may well be in your area late tomorow afternoon
Right just looked it up the B12B is a ceramic hob so its not the pans , by what you are describing it could be a loose connection , with Beaumatic hobs as well as others they have some little links where the cable connects if these are missing it could well be the cause , or the connections on these links are loose , these hobs are designed for single and three phase use hence the links , on problem is these hobs have been discontinued by Beumatic still part should be available if required , check the links are in place
right just opened it up and the previous owner had wired it up wrong the neutral wire was connected to a pin that wasn't in use. all sorted many thanks for help and the abuse!
wouldn't call any of it abuse, more like friendly banter. anyway, glad you got it sorted.
especially now, you can slope off down to the pub, knowing that she can get on with sunday dinner, ready for when you stagger back.
"Drat",just missed this thread.
I know little about induction hobs, but I could have helped with the abuse part
The abuse you were given seemed non existent, a poor standard of abuse indeed compared to what I am capable of
Just as well he had suggestions given about the cooker problem to compensate
Reply to Problem with my hobs = ( in the UK Electrical Forum area at ElectriciansForums.net
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
Hello everyone In September 2023 I rented a beautiful 3 bedroom apartment, with all electric supply, no gas powered appliances. I noted down the...
m having a bit of an issue that is proving difficult to resolve. For 2 years I have been having no problems with my setup. I have a 3 zone house...
