teachingdude
Sorry if it's in the wrong spot, feel free to move.
The specific setup: 12v Bilge Pump wired to a 24v solar panel with a resistor (I think).
The situation: I'm a teacher at a school and we have 2 stream tables that have historically been run with a bilge pump connected to a small solar panel. It wasn't operating for a couple years, but we just got it up and running this last week and I was left in charge of it and I have already burned up 2 motors and have no idea whats going on. One theory was because at first I had them wired straight into it, then saw a little rectangular piece that i am assuming is a resistor. Burned up 1 motor before seeing that, then started adding that to the circuit. My other theory, maybe because it's a 12v pump hooked up to a 24v panel. But to my knowledge this was always the way it was, so I would assume it used to work so it should still work. One more detail, a third (brand new) pump seemed to die today, except it runs fine when I hook it up to a car battery. But when I hook it up to the solar panel in full sun producing 23v, nothing.
So...what do I need to change about my setup to make this work? The goal is to keep it as simple as possible. One of the great parts of this is that the students are able to set it all up themselves by getting the solar panels out and just alligator clipping the wires together.
