Discuss Protecting outside bonding terminals in the UK Electrical Forum area at ElectriciansForums.net
Morning!
Going to be working near the coast and will need to fit earth bonding outside.
I originally chose stainless lugs to bond the copper cables but it appears that stainless and copper are not a good mix due to corrosion so I will stick with the standard copper connections.
I have seen bonding terminals being protected by a type of grease - does anyone know which products would be suitable for this task?
Morning!
what are you bonding, that's outside?
Morning!
Petroleum Jelly, , ,
slap some Hammerite on it. green for earth. red for L. don't think Hammerite do brown.
Reply to Protecting outside bonding terminals in the UK Electrical Forum area at ElectriciansForums.net
Hi there, Just a quick question. Does a main protective bonding conductor require UV protection when run outside? I am under the impression that...
Background: I am not an electrician, I am a retired professional engineer high power broadcast transmitter design , but am dabbling outside my...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Hopefully someone wiser than me can help explain some odd measurements I’ve taken at my own home. This is a long read, I’ve tried to give as much...
4K
  • Locked
5K
