You could use a non-latching pullcord switch with any 4-wire or 3-wire dimmer module, you don't need to buy it as a complete assembly.
All working fine... But I would love to understand whats going on with the voltage.!!
When the lightbulb is in place everything is as it should be.. i.e 230v at P/L in the switch and 2v at S/L (with switch off), however if I remove the bulb I then get 230V at the S/L with the switch on or off??
What is going on?
What is going on?
What's going on is that it's not a conventional switch with contacts that open when off, it's an electronic device with a semiconductor as the 'switch'. Also, as it doesn't use a neutral, it uses the load as a return path for the supply to the internal workings, so with an open circuit output you will, indeed, measure 230V on the output.
