Discuss PVC Conduit Question in the UK Electrical Forum area at ElectriciansForums.net
Getting back to being a little more serious ...
Glue one end, both ends ?
ISTM that unless the fittings are free to move, then gluing the joints will prevent movement due to thermal expansion.
And on a vertical (outdoor) section, glue the bottom fitting (to seal against water ingress) but leave the top joint free.
(Grabs flack jacket and dives for cover) ... Discuss :D
Expansion Couplers For Round PVC Conduit - Discount Electrical - http://www.discount-electrical.co.uk/section.php/107164/1/expansion-couplers-for-round-pvc-conduit bit of a faff using those, yet another product to carry around, I suppose you could use Vaseline, but it would melt in any kind of heat, just talked myself out of that, high melting point grease on the bottom joint and solvent weld the top joint, but only in the vertical, can't see them being waterproof horizontally, but do we need them waterproof or just water tight, the migration of water into a junction box is possibly the concern.
I know it should do this doesn’t it’s the same diameter. So it doesn’t push inside. Not sure if it’s the conduit or the fixings I’ve bought. The fixing are a brand make and the conduit was given to me.
I will get a photo to show you what I mean. I assumed that the fixings should fit inside, so I was a bit confused when they didn’t and thought do I need 25mm tubing.
Sounds like you v been given plumbers waste pipe!? S
Rigid Non-Metallic (PVC) Conduit – preferred for cases where wiring is run just beneath the surface of concrete walls or flooring. It’s primarily chosen because it will keep water that may seep through the wall from the wiring.
Reply to PVC Conduit Question in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
Hello, Im really new to the world of conduit. I have some 25mm pvc conduit and cant for the life of me seem to fit back boxes with 25mm...
5K
Hi Guys Any one know the current carrying capacity of a 4mm 3 core single phase sy cable ran in a 20mm pvc conduit? Not sure of the right table...
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
Hi, I have two questions about domestic wiring In Ireland 1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage...
