Discuss Quality lighting in the UK Electrical Forum area at ElectriciansForums.net
It’s lockdown and the boss decided to decorate the kitchen. We took down a 5 lamp central light fitting while painting the ceiling.
silly me I decided to check the earth from the connection to the metal bulb holders.
four out of five isn’t bad?
photos attached
circuit incoming earth to choc block.
From chic block a wire to 1st light and onward to second light.
Other lights depend on contact through the metal of the fitting through the hole in the thin material. The material is painted.
I fitted an earth wire between the light fittings .
Now this is quality which I’ve lived with for probably 15 years.
shocking . Shows the even if you check continuity of earth .... there’s always something waiting to be discovered.
example pictures
Those serrated washers bite through the paint into the metal, have you checked for continuity?
Yes there was no continuity across the metal from one side to the other. Checked that the ring was tight and wouldn’t tighten any more! Even tried sandpaper round the area?
Sorry my previous entry was not very clear .
when I take continuity test , this is the result.
from incoming earth connector to both sides of stem to lampholder - no continuity.
From other lampholder stem to both sides of lampholder stem - no continuity.
From stem of lampholder between sides of lampholder - continuity.
after fitting earth wire between working stem to failed stem ( under nuts ) continuity works to lampholder.
Reply to Quality lighting in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi guys, I don’t really know where to post this, sorry if it’s in the wrong place. After posting a thread about old lead sheathed cable in my...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi, I have a client with a small caravan site, approx 5 hookups. His old toilet block was nothing much more than an old shed. He's now 'upgraded'...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
