P
PeterPan27
Main protective bonding conductors are to be verfied by test, which one of the following is the main purpose of verifying suitable connections of these conductors?
1- To confirm they provide a suitable path for earth fault currents to achieve disconnection.
2 - To confirm they provide an actual potential between exposed and extraneous parts at the points of connections.
3 - To confirm they reduce overall values of earth fault loop impedance to enable compliance with BS 76 71
4 - To confirmthey provide a reliable connection between the installations main earthing terminal and means of earthing
Any idea peeps?
Any idea peeps?
