Discuss Quick bit of advice please in the UK Electrical Forum area at ElectriciansForums.net
iv got to go to a customer tomorrow to change an immersion, iv worked on these before and had no problems but iv not done one on a pressurised system, is there a specific way to drain the system down, if its beyond be i will get a plumber mate to come with me but its something i would like to try so i have the knowledge, thanks and any adivce appreciated.
Rob
let me know how it works out. i also have not worked on a pressured system. if you have to pick a plumber's brains, it shouldn't take long. LOL.
don't forget to take your test meter/s. LOL.
The pressurised side is the heating side of the cylinder. The immersion will be on the normal hot water take off side of the cylinder which is supplied by the tank in the attic, in this case you can drain down the hot water system as normal as you should not be touching the pressurised side of the cylinder. Unless of course it is the primatic type of cylinder which I have never worked on.
not sure what primatic is?!?!, iv not looked at the job yet but if thats the case then it should be like any other immersion change :)
If my memory is right the primatic type has a bubble in the middle to keep the heating and hot water separate and allows the hot water to be supplied at mains pressure. Not sure if they are used anymore.
Reply to Quick bit of advice please in the UK Electrical Forum area at ElectriciansForums.net
Hoping someone maybe able to help. We have a Horstmann electronic 7 that's connected to the water heater element(everything been great for years)...
Hello again. My car battery is draining completely overnight. I charged it up and ran it through a fairly decent battery tester which resulted in...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
I have Curry's Essential tabletop dishwasher model CDWTT115 for nearly five years. Earlier this year my machine have stopped running during a wash...
Hi Absolutely 0 knowledge of this so excuse language / terms / explanation. Electric only ground floor 2 bed flat ( 3 external walls) On peak...
5K
