SOME (not all) of the manufacturers specify some form of adhesive seal (some also specifically say not to!).
If it's an arbitrary call then I normally put a thin bead of bacterial silicon around/under it just for ease of cleaning and hygiene.
Most builders/kitchen fitters wait until I've done the connections before sealing it!
i once managed to get my hand through a 70mm downlight hole. then had to get the ceiling cut away to get the bugger out. builder and plasterer were quite upset.
Lol!! I can get my little girly-hand through a 65mm hole :)
you've missed your calling then. you should have trained as a gynocologist, wonder if there's going to be a 5 week course.
if he can't then he's wasted as a spark. certain fim makers pay £1000 per appearance for overly well-endowed studs.
chap i worked for once went down a hole in the floor....
ended up cuttin himself out with the fein....
christ almighty lol.
wiring fixed appliances in kitchens is simple.
take a 32a ring , or 2 x 20a radials if your feeling fruity , to a 4 / 6 gang grid switch in an easily accessable location within kitchen.
fit 20a D/P switches in grid unit , engraved and neon lit versions are available for that "hi-tech" look.
run 2.5 from each grid sw. to a single socket at each appliance.
job done.
no cutting off plug tops with all the warantee worries.
no rows of 1 gang units above the worktop.
no filling of cupboards with pattress boxed switchgear.
no discrimination issues between spur fuses and plug fuses.
job done.
ever thought of getting a job doing the voiceovers for JML products biff?
