Discuss ravenheat rsf820/20 programmable thermostat in the Central Heating Systems area at ElectriciansForums.net
Hi every one.
Ive done no heating systems at all. Ive been asked to remove an existing emt2 24hr programmer being used on a ravenheat rsf820/20. And install a programmable thermostat instead in a new place. Are all the programable stats compatible with any boiler? Thanks.
Reply to ravenheat rsf820/20 programmable thermostat in the Central Heating Systems area at ElectriciansForums.net
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi there, We have recently replaced our central heating programmer with a Honeywell ST9400C. We now want to replace our old wireless room...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
What’s the best setup for a system that has a heating system with existing radiators but a wet underfloor heating system is being added to a new...
