Discuss rccd test in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Welcome to the forum. Can you give a bit more info as to how you are testing the device.
Jay we been to know the meter make and model, is it an rcbo or rcd main switch and whether the fail is immediate and what does the meter indicate.
It thought it might be cause some of the loads where still connected, but when testing a rcd , u can normally still carry out the test with loads still connected.
Reply to rccd test in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
I live in Australia; you can use a socket tester to test the RCD for the power outlet circuit. Plug device to a 3-pin wall socket, set testing mA...
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
I would like to get some information on what protection is on a multi meter when accidentally testing a live circuit while the meter is on the...
What should you do if a client has a CU that is a split board protected by 2 * 63Amp 30mA double pole RCCDs, you took Zs and tested both RCCDs by...
I have a factory fitted rare satnav for an old Honda Prelude with faulty screen. The lights and buttons light up and make noise when pressed but...
