RCD / LED problem
E
Emkey
Hi,
I'm new to this forum and I would like to get some advice.
I was asked to install a 6 way DB feeding four 3ph tanning beds. I installed the board (Hager 100A 30mA RCD as incomer, C32 MCBs )and isolators, tested the system and left. The sun beds installers team arrived this morning. After connecting the beds they rang me and said that three of the beds trip an RCD when on standby. They also said that they are sure the beds are fine. Every time they tried to start any of those three beds an RCD tripped.
The rest of the electrics in the unit are fed from a single phase (L1) CU which was already there. One of the circuit in this CU is B6 MCB feeding about ten cheap ebay LED drivers for LED light strips. There is no switch on the circuit so those LEDs are being switched on and off by operating an MCB.
The bed installers noticed that with this LED lights circuit being OFF, the RCD incomer on DB trips when they turn the beds on. With the same light circuit ON, the beds seem to work fine.
DB and CU are two separate units. Have any of you ever came across anything like this? I'm going there early next week to give it a good check and I'm trying to build some plan of action.
Any ideas?
Not sure the upfront RCD was a good idea.
Borrowed neutral?
Have you got an earth leakage clamp metre?
b6 not c6 then or 10amps?
wired up wrong !
Don't have earth leakage clamp metre but might get one.
RCD required by the customer, apparently something to do with insurance or council.
RCD incomer feeds only the four sun beds. There are no other circuits in DB.
What are the sunbeds connected too? (eg socket)
Why have the council stipulated RCD protection?
Are you a electrician?
It could be a bad idea but I have seen five beds running on a single RCD without any problems.
But why a light circuit in a separate consumer unit affects an RCD which it isn't wired to (without tripping "its own" RCD inside CU)?
The sunbeds are connected to 5-pin interlocked sockets.
RCD is required by the customer and the installers.
Yes. I am an electrician.
Hang on is the RCD required by
1) insurance
2) council
3) customer
4) installer
You have told us 4 different things in the space of 5 minutes
Can we rule out that these LED lights are nothing to do with the sunbeds? Edit these are just doing lighting in the shop.
