Discuss rcd with automatic reset in the Electrical Tools and Products area at ElectriciansForums.net
I saw this interesting device in a gewiss catalogue.Called restart.Its an rcd which resets itself after testing that there is no insulation damage to the cables.It also performs a weekly trip test on the device,without dropping power to the installation.No idea on the price.
Got a link?
Must admit, cant see how this would work if there is a faulty appliance upstream still connected?
Hi Jason6930,not exactly a link,but if you google gewiss.com and click on to their catelogue you will see the pdf for rcd restart,and some bumph about how it works.If there is still a problem it wouldn't reset,but maybe would come in handy if a blown bulb would take out an rcd.
Ive seen this product advertised after seeing a link on an other forum(screwfix i think). - Seems to be used a lot abroad? - good idea if house empty and freezer full of food when RCD trips. - If this is the same one it attempts to reset itself if the fault has cleared. - clever stuff (maybe to clever though)... http://www.gewiss.com/irj/portal/focusonrestart_IN
Reply to rcd with automatic reset in the Electrical Tools and Products area at ElectriciansForums.net
Hi, I seem to have an RCD that keeps cutting the power at random times without actually tripping, if I reset it, the power comes on and will stay...
Hi I am asking for help as a novice and 1st time user of this forum. Recently started to experience tripping of MCB & sometimes with the RCD at...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
Hi I know I have to do more testing but I just want to see if there is something I’m missing. Customer said light fitting in the loft was...
