B
BillyTheSparks
Hello all.
I've been asked to re-lamp all the canopy lights above a petrol station forecourt, it is to change the Sodium lamps to LED lamps. I am unsure as to what qualifications I need, or what explosive regs I would need to adhere to.
I've tried googling etc. but there are so many differing answers, the mind is turning to mush.:banghead:
So I thought I'd ask the experts on here! :smart:
The bloke who owns the garage would like (as with ALL customers) it done ASAP.
Many thanks in advance
Billy
To work safely on Petrol Forecourts you need S.P.A, you won't get near a Major without one, but your job is obviously not with a major retailer.
S.P.A is only voluntary.
The canopy is outside any Zones.
If your going from sodium to LED, it's not relamping
Ok, so what is S.P.A?
I'd be using a scissor lift to get to the height of the canopy, so that will be within/close to the zone of the pumps. Would that prevent me from being able to complete this job?
I would like to do this job, but the last thing I want, or need, is the H&S bearing down on me.
I know that it isn't technically re-lamping as I need to disconnect the ballast/control gear and by-pass it, but for laymans terms this is how myself and the owner have be discribing it to each other.
The garage is a BP garage, but the bloke who owns it isn't part of BP. I believe that he owns the franchise?? (If that is how it is, I'm not overly sure. I will have to ask him tomorrow)
With regards to the new lights I would get a rep from a couple of lighting companies to look and give you some option perhaps dextra or thorlux and thorn
He has already ordered the lamps, he obtained my number from the wholesalers that suppied him with them.
wait till tony, eng54, darkwood or outspoken read your thread. they know more about petrol station regs.
I’ve had little experience of petrol, I’ve worked with natural gas most of the time. They are two different beasts, gas rises, petrol vapour falls.
Given the danger of the electrical set up on a scissor lift you may find yourself a bit higher than the canopy. They have a contactor panel in the base unit. Contactors equal sparks! As has been suggested a portable tower is the only way to go.
Safe isolation goes without saying.
Power tools are going to be another problem. One that with a forecourt I don’t know the answer.
Thank you for the info regarding the vapour properties, and about the contactor set-up in the base of the scissor lift. That was one of my concerns.
The lights will be disconnected - there is no way I want a spark!! And I wont be using any power tools.
I have read that I wont be able to carry out any Zs tests due to the voltages that will be present during the test. So I was thinking just to do R1+R2 then calculate the Zs using the Ze test socket. And as I'm not ofay with testing petrol stations I'm not too sure as to whether this is correct or not.
So any advice regarding this would be appreciated.
Cheers
Billy
