Search for tools and product advice,
Discuss recall on fuse wire in the Australia area at ElectriciansForums.net
Is there no such thing as R&D or routine quality checks in the electrical industry anymore ?
Electrum springs to mind !!!!:disappointed:
Didn't another member raise this as a concern when he got called out to "glowing" fuse wire?
I'll see if I can find thread
This firm must be run by accountants or an investment group, complete asset strippers with no common sense, probably killed off their own R+D and QA departments to scrimp a few pence off a low volume, low margin, safety critical component.
nasty nasty recycled copper with bits in it.
I know a chap that runs a nuclear fuel reprocessing plant and the steel used for parts of the process containers, HAS to be mined from scratch, they specify the mine, and it has to be a german one!
Sehr Gut
Reply to recall on fuse wire in the Australia area at ElectriciansForums.net
Wiring cooker hood into a switched fuse spur with a 13amp fuse in the spur. The cooker hood is 3amp. Should I swap out the 13amp fuse in the spur...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi ive recently got myself a mig welder for my garage but each time i try to use it it trips out. Ive spoken to an electrician and he said its...
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
Hi All, Can anyone help with calculating a Zs value for the fuse described in the title. The fuse sizes in Fig 3A3(c) of the 18th edition wiring...
