Discuss Recessed consumer units in the UK Electrical Forum area at ElectriciansForums.net
I had to fit a recessed Hager consumer unit with a metal recess and plastic cover (before we went all metal) was easy to fit I think that they do/did an on-line video showing install, looked good too.
Why a recessed one?
Wylex do a over sized cover for their standard boards, just fit the board in the wall and after plastering fit the new cover in replacement of the old supplied cover
Wylex don't seem to get much of a mention on here when regading to domestic consumer units.
Why a recessed one?
The existing consumer unit that i'm replacing is recessed and she wants to keep it that way.
Has one retro fitted an SPD device? Only fitted ones that come with the board, im guessing you feed the SPD from an MCB along with a N & E
Reply to Recessed consumer units in the UK Electrical Forum area at ElectriciansForums.net
Hi, want to installed some LED strips in the ceiling and wanted to know how the recessed LED profile is fixed in place and stop the plasterboard...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Hi. Can a horizontal 200A consumer unit be fitted vertically, or is there a vertical configuration? I have a 350mm wide space...thanks.
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
