Discuss Recommend - Cable Shears / Cutters in the UK Electrical Forum area at ElectriciansForums.net
Dustydazzler
Supporter
I am after a new pair of cable shears for chomping meter tails and thick twin and earth.
I have had some ITL ones and NWS ones in the past
But fancy a change ….
https://www.amazon.co.uk/C-K-3963-C...VD8V65MVE2DZ&refRID=W6G104EVVD8V65MVE2DZ&th=1
Best I've used so far.
Keep a razer sharp edge as long as you only cut what you are supposed to.
I use the smaller 210mm for nearly everything, cutting, baring the ends.
Not insulated, but that doesn't matter for me.
Edit: the description says for 6mm dia cable, I'm fairly certain this is a missprint as my smaller ones can be used with ease on 25mm conductors.
I have a couple of pairs same as the ones Rob linked to, but Bahco branded.
They really are a lifetime tool if not abused.
Same as above Knipex Cable shears with 200mm handles double jawed first jaw for just cutting/scoring down to copper (if lugging a cable example) second reserved for chopping cables.
* just what I do to keep them razor sharp.
Bearing in mind that we are about to crash out of the EU shouldn’t we be planning ahead and listing good quality UK manufactured products and tools? We don’t want any of that German rubbish for instance.
i just use my teeth
images
Reply to Recommend - Cable Shears / Cutters in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm new to this forum and trade as DF Electrics - Small Job Specialist based in Ellastone, near Ashbourne, Derbyshire. I'm now back on the...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
Hi. I live in an older house and I have old white twin and earth cables going through walls in large white pipes. Unfortunately, some mice managed...
Hi all. I am installing some metal trunking vertically in a meter cupboard to contain all the meter tails for an apartment block. I have 5 sets...
Looks very strange to me. Obviously had a new fuse carrier fitted to it at one point but the two cables on the left go to the meter as normal...
