I
ian
One of the plumbers I work for has asked me to wire an under floor heating system into a rehema broag 35kw combi boiler which also controls rads. I have only ever done this before on 2-zone boiler. (2 switched lives, one for the CH and the other for UF heating or a combination of both) however, this boiler has only one switched live input and an internal time clock.
Apparently there is only 1 – 2 port valve needed to make this work, but cant understand how.
The valve will be installed after the above the UF manifold and will be controlled via the room stat for the conventional heating. That part is straightforward, but I can’t understand what will stop the UF heating from warming up when the boiler is heating the rads.
There is a HF heating pump which has been fitted to the return leg of the UF heating system, a stat has also been provided, but I cant see how its going to control the UF heating.
If the heating system was a S or Y plan it would be simple, but I cant understand how it will work with a combi.
Hope the above is clear and you can understand my rantings.
Ian
I think I might be able to help, but need a clear picture in my head of what we are up against, I have done some pretty complex heating systems in the past ( with the help of the plumber ), so if you you are desperate then email me you no. and I will give you a bell and try and help [email protected]
cheers buddy,
i will do once i have seen what i am up against. going to see the job later in the week.
ian
