Discuss Reliable p.i.r. motion detector? in the UK Electrical Forum area at ElectriciansForums.net
Syncopator
Over the last 7 years I have replaced a p.i.r. activated security floodlight 3 times.
Not surprisingly it has been the detector which failed each time, not the light.
Having spent my professional life in electronics, I would, a few years ago, have designed and built a reliable replacement myself, using good quality components with known pedigrees. But I just can't be bothered any more.
So, can anyone recommend a good, well built, and above all, reliable p.i.r. motion detector? Preferably something designed and fabricated in the U.K., not in the honourable far east.
In my experience the most common cause for failure of such units is the positioning of the pir detection being in direct sunlight. Like with everything else these days, you usually get what you pay for so don't expect a unit for £10 to be as good as one for £80
I use the Robus fittings , every one I've fitted has had no problems at all , I get em from Denmans , not that expensive either
I have used the Luminite Omega Pir now for over 20 Years. In that time i would say i have replaced only 3 which have become faulty. Maybe not as small as more current pir detectors but bullet proof. (Not literally ?)
I feel your pain.......i have exactly the same ongoing problem! :( i installed 16 PIRs in a lorry yard beginning of last year. iv replaced 6 so far.
the timeguard PIRs seem to be reliable.
Reply to Reliable p.i.r. motion detector? in the UK Electrical Forum area at ElectriciansForums.net
Hi all Recently we've been having a few issues with smoke and heat detectors.. been fitting them for years and years now mostly without any...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Having a bit of a nightmare with what should have been a simple job. Back in January I replaced some old Varilight dimmers which had failed after...
