Hello everyone,
I've recently had to replace (for a second time) a Corroded Strip Light Jointing Clip - see attached photos.
Both times the LED strip had stopped working because of this. It's located in the interior, in a (theoretically) dry spot.
I'm a little worried about this happening again - and about any security issues.
Because of this I am considering soldering the connection between LED strip and Driver.
What do you think?
Any tips?
Many thanks!
there must be dampness getting in from somewhere?
Is it a cold room? near an open window? bathroom or kitchen?
Is the tape itself showing signs of corrosion?
It's in the top corner of a room - both external walls and roof. It's our office, so not constantly heated.
To be honest, apart from this corroding, I haven't been able to see any other signs dampness around - and it would show as we have a yellow MDF cladding.
The rest of the tape is also fine - although it's housed in a diffuser strip, so better protected.
I was even considering putting a damp-trap next to it, but it seems almost a bit comical to do this.. I'd much rather have a permanent and proper solution to this..
Any thoughts?
Many thanks!
The metal looks like its been overheating... but these tapes dont generate a lot of heat themselves. Is there a good spring connection when the tape is pushed on?
Could this connector be somehow housed in an IP rated enclosure? i know that sounds a bit comical as well though
I wasn't too happy with the connections to be honest - they didn't fill me with confidence as a bit fiddly and not too "solid".
If I soldered the connection, would that perhaps help create a more solid connection and avoid the overheating?
Is the silicone grease meant to seal and protect the connection? Do you think I should buy some?
Many thanks for your help!
I know what you mean!
I have always found soldered joints to be more reliable. Ensure you don't end up with a 'dry joint' though!
Never had an issue with heat but the tape in any case should not reach a high enough temperature to cause a problem on a soldered termination.
Smearing the termination with silicon grease will prevent any corrosion/reaction if damp, so yes buy some.
Hi again - it's been a while, but I have a quick question if that's ok?
What is a dry joint, so that I can avoid it?
Many thanks!
Dry joint refers to a poor soldered connection leaving a high resistance connection or no connection at all. Probably derived from the term wetting used for soldering whereby both parts need to be hot enough for the solid solder to get wet so it can merge. If this doesn't happen you end up with a dry joint.
