Discuss Replacing lights in a 2009 d22 navara instrument cluster in the Auto Electrician Forum area at ElectriciansForums.net
Hi,i am not certain they are replaceable....they may be led's soldered in to the board.
What is the issue?
Hi,the older models,of which yours is,have no dimmer switch,and use incandescent lamps (normal bulbs) of 1.2W or 2.4W. You should be able to pull them out,if not overheated.
You can check which lamp does what,in a darkened area,using a torch to illuminate form the rear,when you have removed each lamp.
The later vehicles tend to have integrated lamps,in the instrument cluster,to lessen the ease of 'modification' of warning lamps associated with MOT fail issues....;)
Reply to Replacing lights in a 2009 d22 navara instrument cluster in the Auto Electrician Forum area at ElectriciansForums.net
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
My passat had an incident where Battery acid leaked and it damaged ABS Module, various light on dashboard switched on. Auto hold, cruise control...
I replaced a single pole to exterior lights with a smart switch. Next to it is a 3way to my foyer light. The foyer and the smart switch to...
Hello everybody from Germany! I'm feeling sick with this car, it won't start, just very rarely...please help me out. Car: Opel Corsa C 1.2 2003...
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
