Discuss Replacing T8 fluorescent tube in the DIY Electrical Advice area at ElectriciansForums.net
George B
One of the fluorescent tubes in my undermount lighting system burnt out. There are 3 independent tubes/ballasts under the length of the kitchen cabinets and the others were still on.
After carefully replacing the affected tube, it seems that all three lamps are now not working.
The breaker panel is fine with no issues (other appliances are functional).
Appreciate any insight on the problem.
Is the new tube identical to the old one ie same voltage, same wattage output etc? Can you post a pic of the writing on the old tube as well as the new one? Did you replace the starter as well? If so is it also identical specifications? Also there might be 3 separate tubes but they could be series wired meaning a problem with one tube could result in more than one not lighting. How many starters are there in that light fitting?
Reply to Replacing T8 fluorescent tube in the DIY Electrical Advice area at ElectriciansForums.net
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
Hey all, So this is probably a quick question. I have some under-cupboard kitchen light tubes that are old and have clearly blown at some point...
I’ve got bad ballasts and am replacing the T12 fluorescent bulbs with Halco direct wire, double ended T8 LEDs. The fixture has 4Rapid start bulbs...
I'm encountering a problem with the lighting in my kitchen. I reside in an apartment that has a light fixture utilizing 2 T8 fluorescent bulbs...
Hi, I'm troubleshooting a 'smart switch' issue which is connected to an existing fluorescent 4' 2-bulb (T8) fixture where I have replaced the...
