Discuss Reverse kit in the Auto Electrician Forum area at ElectriciansForums.net
This diagram may be of help.
To make sure test at the plug with reverse on and off.
Make sure to seal properly all the holes when you run your cables as to prevent any water ingress
Reply to Reverse kit in the Auto Electrician Forum area at ElectriciansForums.net
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi everyone, On my Hiace the roof LEDs are triggered by the side door that breaks the ground, not the positive wire. I want to also have an...
Hi guys, im currently trying to start my new big block chev in a chevelle but having issues.. im a full novice on electrics so be gentle ! The...
Hello I have a problem with my 2010 Kia Sorento kx2. I recently bought a second hand trailer. I was told all the lights were working so I plugged...
I bouught a Nissan Townstar EV and have found what I consider a theft problem All previous vans I have had allowed the driver to enter and exit...
