S
stef
Hi,
I have a Robin Smart PAT 5000 tester, can't find the book, can't remember how to clear the memory.
Anyone who can help, please?
Thanks.
Hi Stef
Dont have a Smart Pat 5000 manual but the 5500 manual says the following:
From the main menu
Stored test records can be deleted individually or all at once. To delete records press the clear button, the screen displays:
Select record with UP/DOWN
Press Go to
and then
Clear record. Hold GO
down to clear all
NOTE: Once deleted records cannot be retrieved.
Last para is good advice so hope you have downloaded any test data you want to keep!
Hopefully it is the same on the 5000.
I can see that you got the problem sorted. If you still need it, PM me and I can e-mail you the instruction manual in a pdf.
