I'm wondering whether it's worth investing in a rod set? They seem quite expensive so are they worth it? How often do you use them? Do they work round tight corners? I currently use the old string method which sometimes works great but obviously has it's drawbacks!
I have a super rod set and a cheap set. The cheap set comes out when there's a slight risk of not being able to retrieve the rod. What I will say is although expensive the super rods are brilliant and notably better than the other rods used in conjunction with the variety of attachments you get with mega set. Well worth the investment as they've saved hours on some jobs.
No work today Ant?Had a cheap set from Aldi served us very well for the cost however we have lost, snapped and got most of these stuck now. Does these magnet, chain, grab hook come as standard and does anyone know if they fit on other makes of rod.
no having a sort of day off we have to take equal days off holiday new job just starting will take up till Christmas in a bit early so taking it now also got to do accounts.No work today Ant?
