Discuss Rotary Isolator that takes 2x16mm? in the UK Electrical Forum area at ElectriciansForums.net
Does anyone know of a rotary islotaor, weatherproof, that'll take 2 x 16mm incomers? I've got long runs out to parking bollards so they've had to size up the cable for volt drop.
I could do it with a street light cutout but it wouldn't allow them easily isolate it.
Many thanks for any help.
Fortunately its not on my head, been designed by a consultant being an airport. The runs are about 150m each so its more for volt drop than anything. Basically going to be an isolator on the outside of the pillar, going through the back to a spur which will then feed the gubbins inside.
Reply to Rotary Isolator that takes 2x16mm? in the UK Electrical Forum area at ElectriciansForums.net
Incoming supply on our job comes into the building and then the tails from which go into a switched isolator with 200A fuses fitted. No idea...
Domestic property Supply number 1 6 flood lights 4x400watt= 1600 watts 250meters from board to closets corner of tennis courts Tennis court...
All of the work described below will be completed by a qualified electrician, I am just curious and using the info for planning!! I am planning a...
4K
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
