M
Mark_Burgess
sorry to change subject alittle but,as u say lenny bridging moisture gap, how does that relate to the pump in type cavity wall insulation. had mine done 2yrs ago now seem to have a lot of damp. any advice anyone?
Some of the older insulation was of a porous type so that when the driving rain soaked through the outer wall it wicked through to the inner wall causing damp. The new stuff is supposed to be a silicone based product, I don't believe and will never get this pump in stuff done.
A mate of mine how is a builder, has partially pulled down a pumped insulated wall in prep for an extension, the black mould damp was unbelievable.
I truly believe in insulation whilst a new build as an air space cavity still remains.
Back to running tails through the cavity, I usually use a but of 40mm waste pipe, that can be sealed into place and a little bit of intumescent pillow in the pipe sorts the fire barrier.
