I have bought a Lenovo x3850 X6 server to tinker with at home. It has 4 x 1400watt psu's each with a kettle lead socket, I imagine for redundancy.
I am hesitant to just plug it in as I don't want to overload a double socket?, the room I have to use it in only has one double socket and I am concerned about running all of the power through that one double socket.
What would you recommend as the safest way to run it ?, I did wonder about having it draw power from that socket and another elsewhere in an adjacent room with an extension lead.
Any suggestions welcome,
i doubt any of them will take the full 1440W at any one time... that's just the maximum you can run it up to. Unless your mining crypto.... it shouldn't be an issue
Saying that, it is sensible not to run it all from the one double socket and a 4 way extension lead
Is there a possibility of running a new circuit just for the server?
Thanks for replying,
I think that's what I am going to do providing there is a spare output on the fusebox under the stairs....
I don't feel confident doing it myself so I will get in a professional to do that part.
the professional may have a better idea of the load as well... but if the unit comes with a 13A plug, it should be ok just to plug and play.
The Lenovo spec says maximum mains demand from all PSU's is (for 4-socket): 3,505 kVA
Don't know if you've seen this guy playing around disconnecting them while the machine is busy rendering! His total server power (on the DC side, so prob need to add 20%) when actively processing seemed to be between 880 and 1500 watts
View: https://youtu.be/3Yp9V9BkT4c?feature=shared
So I suspect you would be fine plugging all four mains leads into a twin 13A socket! You'll be able to see what its using.
You'd need to look into the specs - but typically the multiple PSUs are for redundancy, not total load. Usually you can choose differing PSU quantities depending on what's fitted (more CPUs, more memory, more disks == more power needed) and whether you need redundancy. So it may be that it only needs 2 or 3 of the PSUs to run. It can be that it will run with less PSUs than it needs to start - a friend had that some years ago with an HP server, he hadn't got round to replacing a failed PSU, and found (after a shutdown for power failure) that though it would run fine on 2 working PSUs, it couldn't power up on less than 3 🤔
If (for example) it will run on 2 PSUs, I'd be inclined to run 2 PSUs off a UPS, and 2 direct from the mains. That way, the UPS can keep it going (for a graceful shutdown) if the mains fails, and the mains will keep it running if the UPS fails - yes that's a real problem :(
The specs can be found at Server features and specifications | x3850 X6 and x3950 X6 | Lenovo Docs - https://pubs.lenovo.com/x3850-x6-6241/nn1em_r_ugch1featspecs and some guidance on power draw is given :
Input kilovolt-amperes (kVA), approximately:
Minimum (4-socket): 0.146 kVA (idle)
Minimum (8-socket): 0.292 kVA (idle)
Typical (4-socket): 1,260 kVA
Typical (8-socket): 2,520 kVA
Maximum (4-socket): 3,505 kVA
Maximum (8-socket): 7,010 kVA
So depending on the configuration you have, it could run on as little as 1 PSU. But I'm guessing that if it's been configured with the maximum PSU quantity and rating, it's configured more towards the more hungry end of the spectrum. I hope you don't plan on having it in a habitable room - while it'll keep the place warm, I suspect it will be "a tad noisy" unless you are stone deaf :eek:
