Discuss Salamander HomeBoost Pump Installation. in the UK Electrical Forum area at ElectriciansForums.net
LEDdriver
Hi All
I am looking to install a Salamander Home boost pump under the kitchen sink cabinet. Need some advise:
Currently next to the kitchen sink cabinet I have the dishwasher and Washing machine which are individually connected to fused spur and socket and I don't have spare fused spur and socket for the pump.
Need some advise:
Q: Could an additional spur and socket be installed for the pump via the ring and would it need a minor works certificate or a full Part P compliance certificate - as shown in the first two pictures(blue is existing, red required). Drawback a lot chasing into the wall etc will be involved.
Q: On the opposite wall, I have a spare fused spur and socket. Could I replace the socket with a flex, run 2.5mm 3 core 25A cable, under the kitchen cabinets to behind the sink cabinet and install a socket there. Effectively not altering any circuit, only moving the location of the socket after the spur by about 7m cable extension.
Only about half a meter of cable visible on the wall, rest hidden behind the kitchen cabinets - as shown in the last picture.
Would this require a minor works certificate?
The max current rating of the pump is only 1.8 Amps.
What would be the best option?
Thanks a lot.
Reply to Salamander HomeBoost Pump Installation. in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Doing some work in a commercial restaurant/kitchen the builders had already boarded and plastered the walls meaning my only viable route is to use...
Hello all, I need to have an electric car charger installed but at the moment I'm puzzled about what my options are. My garage is at the back of...
Hi, I'm going to be installing an outdoor socket, have no problem with the outdoor/socket side, but when bringing the internal end or the SWA...
