Dont you mean Stork :ciappa:?
But I think you will find it was.............(quietly) Flora :grin:.
Boydy
Lol, you are quite right, Stork!
And I'm pretty sure it was their tubs I am thinking of - I remember white storks on various coloured backgrounds. But my mind could be playing tricks on me. The tubs were quite solid for re-use - hence the colours, so you could remember what you put in them. Maybe Flora made similar ones.
I did the most bizarre internet search - "historic margarine tubs", but couldn't see the ones I am thinking of!
Anyway, butter beats them all IMHO, but I can't see a butter wrapper making a very good dust cup!
Thanks - you mean not saying something like "I was asked to make a hole in something so I tried to use my drill (don't know what kind). It didn't work though. Does anyone know why not? Or what the thing is made of? Or if I should check if the right kind of bit is in the drill, or if there is a bit?"
I am bound to make a fool of myself now!
I was thinking more along the lines of: "Hi new here just done a cu change and the rcd keeps tripping any ideas??" :banghead:
Horses for courses.
I have my Dewalt 18v combi for light stuff, a cheap 110v Ryobi SDS that I've had for about 7 years and a Milwaukee core drill I've had for longer, that I use for well... for core drilling.
I used the Milwaukee to put a 4" hole through 2' of black basalt not that long ago.
I can assure you even with a decent core bit it was nothing like a hot knife through butter.
I work on the principle that if I use each drill for what it's designed for then I'll still be using them happily for years.
Horses for courses.
until the 'labourer factor' or the 'van's 3 flights of stairs + 5 min walk away factor'!
Horses for courses.
I feel your pain.
It's jobs like this when you need a rig to fix the machine to so all you have to do is turn a handle to feed it through the wall.
Not something you would want to buy on the off chance you'll need it someday, but maybe worth hiring now & then.
http://www.edcoinc.com/core-drill-rigs-36.html
Or the 'yet another thing to load in the morning, unload at the job, load at the end of the day, unload back home' factor. Exhausted and out of time before any work has even been done!
Reckon if my 18V combi will cope with the occasional solid board access hole, then so will my SDS... If I need to do loads on a job then maybe I'll hire...
you need a rear handle 1000 watt elu drill and a diamond tipped cutter mate theres no magnetic slip clutch, if it binds you get a busted arm
the nose of the elu drill will go through the hole that the cutter bores if its a 4 inch hole for fan ducting/ soil pipe
