Hi all, I'm very new on here and after some advice and help on a number of domestic wiring questions I have...
I have recently purchased a 1920's bungalow that requires rewiring. The property has floor boards with approximately 30cm void below the floorboards where I intend to route new twin & earth to supply sockets. Can anyone advise if the cable needs to be clipped to the joists or if it is permissible for it to lay on the ground beneath the floor boards? and if clipping is required, what interval should clips be installed? I am trying to keep the number of floor boards I need to lift to a minimum.
