Hi all, I'm very new on here and after some advice and help on a number of domestic wiring questions I have...
I have recently purchased a 1920's bungalow that requires rewiring. The property has floor boards with approximately 30cm void below the floorboards where I intend to route new twin & earth to supply sockets. Can anyone advise if the cable needs to be clipped to the joists or if it is permissible for it to lay on the ground beneath the floor boards? and if clipping is required, what interval should clips be installed? I am trying to keep the number of floor boards I need to lift to a minimum.
To rewire old propertys it's hard to clip.
Especially thiers a low void.
You can only clip where you can, to clip
Use the hammer length clipping distances, to clip to the joists you would need to take possible every board up.
Agreed, clipping at the full length every 30cm would require most of the floor boards to come up and they probably wouldnt go back down nicely. I wasnt sure if the T&E can be left laid in the ground or if it needs to be clipped, what the absolute maximum reasonable clipping distance would be. Thankyou for your comments.
