Search the forum,
Discuss selection of power capacitors in the Australia area at ElectriciansForums.net
S
snaban
Will someone give links(or charts) to download the sizes of power capacitors required for
induction motors of various hp,rpm,design code for the purpose of
a)reducing starting current
b)power factor correction
Capacitor sizes can vary for the same size motor depending on the manufacturer as can the pf. The pf of a single phase motor can also vary depending how much load it's under. What brand of motors are you dealing with and what type of motors are they (CSR, PSC, CSCR, CSIR etc)?
Reply to selection of power capacitors in the Australia area at ElectriciansForums.net
Hello, I am hoping this is in the correct forum. To start, I acquired a film processing machine that runs on 3 phase. Now before getting the...
Hello ! I am building for some time a cct to drive a 3digit multiplexed LCD. (from aliexpress) From the sellers on aliexpress I managed to find...
Hi Guys, Is my understanding of why it is bad for a star/delta motor to be stuck in star correct? 1) Star delta starting is used as a method of...
5K
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
