Discuss Service cable burial location in the Electricians' Talk area at ElectriciansForums.net
C
chronyx
I need to sink an earth rod in the general area of where I know the service cable is buried. There's a thin layer of hard standing to break through then it should be soft clay soil.
Basically just need to know if the cable comes out the front or the side of the house. Can't see from inside.
Is it worth asking SSE Power Distribution if they have a record of the cable location?
Any other ideas other than luck and extreme caution?
Suggest fitting the earth rod where you know the DNO cable won't be rather than play Russian roulette by hoping you don't hit it.
use a cat and gen,but using them close to foundations gives spurious indications.
common sense approach is best option.If you think your close to gas or mains supply or water,or even soil pipes.just use containment to move the cable a bit further away from that area and knock the earth in, and add a little extra on for the time and materials.
Two welding rods bent at right angles and divine for the cable, I had a 80% success rate when I wer a lad
i'm with dave. dig carefully by hand. seen too many builders go in like bulls in a china shop with a digger, then moan because nobody told them there was cables/gas pipes/water pipes there. maybe that's why we are considered to be the top trade, in spite of the scams thinking that anyone who's done a 5 week course can be considered competent.
I'm also with Dave, I hand dig the first 600mm carefully and usually try to twist the rod in by hand for the first 250mm after that if it's just sand or soil so you can feel any obstructions.
Reply to Service cable burial location in the Electricians' Talk area at ElectriciansForums.net
Hi All, I have a client who is developing a plot of land for a single house. Currently, their 100 amp service cut-out is in a cubicle fed by...
Hello Everyone, I am building a new home in Illinois and will be running 400 amp service from the street where the main ComEd electrical line is...
Hi all. First time poster here. I did find one thread on here that touches upon this topic, but my setup is a bit different. I want to install...
A quick search for earth tape didn't come up with much, though this thread was of interest. I'll start by mentioning that I've led a sheltered...
5K
Hi, Can I ask some advice on what to bury please? This is the the front of my house in plan view. House at the bottom. Porch at the bottom left...
