Yes lol... wasn't a dig just advice, i wouldn't put my money in a bank that couldn't spell 'Finance' as you have to question their abilities when they can't do basic English and especially a word that is strongly linked to their proffesion...
In other words on here you'll just get a jibe about it but to a customer it could be what decides if you get the job or not, or the impression you give about your company.
Thats fine mate, No offence taken.. To be honest its a pain when filling in certs, Where customers want cert there and then to hand over payment i often find my self texting the wife, Or typing the text in my phone. (Trouble is that usually its that bad even the spell checker rejects to give me the correct answer
And yes I agree.. Doesn't look professional, However hasn't caused my to lose a job as a result (Or that im aware of)
Well cable was a lot more expensive back then, that's why it was common place to borrow neutrals, re-use rubber cable that may of been difficult to replace and not bond anything. Probably too busy with all the ample work to worry about such things anyway, lord knows fuel was too expensive to run to the shops and back if you did run out of cable :rofl:
It's profession.
See me after class !! :53:
Already got detention for it Geordie... was spotted earlier but il take it on the chin and not edit it ;)
Caught red-handed :bomb2:...... we all do it but was with respect to the word neutral a deeply embedded word in our trade ;)
Well spotted or did i put it there on purpose ;) .....No! i won't get away with that one will i lol..
That will be because it's negative !
Shared Neutral seems to be the wrong definition as its the line thats normally shared !
Sent from my Poundworld talk99p
Ask yourself this.....if you do get caught out by a borrowed neutral and end up putting two lighting circuits on on RCD, what is worse, not subdividing the circuits as the regs suggest or having no RCD protection?, i would of thought that is easy to answer
Being the lesser of 2 evils still doesn't make something right. The best thing to do would be to rectify the borrowed neutral.
A few months ago a found a borrowed neutral taken from the upstairs socket circuit going to the upstairs lights. Lovely.
Adam, how would you find them in the winter on a site visit at 6pm on a jam packed 3036 board?, not having a go just curious
When I have to do as you describe there, I pick a light circuit, knock it off take the neutral out and check for continuity between that and the main neutral block. Only takes a couple of minutes and the customer usually likes eeing something not too inconvenient switched off and the meter out. Value for money on the free quote.
Winter's evenings are the reason God created head torches. You could certainly have a look at what kind of cable it is, in the board and at the rose - if there's double insulated singles my suspicions may be aroused. If T&E you should be able to identify the neutral at the board, meaning you should be able to check r1+rn continuity at the rose.
I'd probably spend more time checking the landing light because that's where you generally find them, but I think you need to do more in the way of testing than just looking at it and saying "Yep... You're gonna need a new fusebox".
