L
LlandrilloSpark
If you test continuity of a lighting circuit neutral to the block surely you should get continuity?!!
If I know there are two circuits then one way is to IR between the Neutrals of each circuit from the roses or pendants but that needs to be done in daylight with power off , in my experience it usually happens in the two way between hall & landing lights
