Discuss Shaver skt with double outlets in the UK Electrical Forum area at ElectriciansForums.net
Anyone know if you can get a bathroom rated shaver socket with two 230v outlets (for 2 toothbrushes). Or alternatively smaller units?
Or would it be ok to use both 115V and 230V skts simultaneously with two toothbrushes?
They are such a lump arent they.. why can't they be smaller like the ones you get integrated with shaver lights?
I see Greenbrook do a single gang size so 2 of these might be ok.. they going inside a cupbd in a shower room.
Never seen one, it would have to contain two transformers. I guess there is little demand for them - realistically, do both toothbrushes need to be charged at the same time? As a last resort, install two singles side by side.
No they wouldn't need to be charging simultaneously but I think it's more the convenience factor that you park your toothbrush on your own charger. Like you would charge your mobile on your own charger..
You could address this from another angle and buy a 110V electric toothbrush and then use both 230V and 110V sockets simultaneously - after checking the chargers together don't exceed the rated output of the socket
Yes I wondered about that. One might charge up twice as fast but don't think that would be an issue.
Might be worth checking if you can actually plug two in together, at the same time. I’m nearly sure you can’t as it’s either 230 or 110...I could be wrong here. Just some shaver sockets have a selector switch to go from 230/110...
Reply to Shaver skt with double outlets in the UK Electrical Forum area at ElectriciansForums.net
Hi, I live in a property built in 1911. It has had asbestos artex applied to every ceiling in the house. I am currently creating a new...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
  • Locked
5K
Hi All - Hope you all had a good Christmas! I have just recently started my own business and struggle to price work as never had anything to do...
8K
Hi I had to move a double socket and change it to 2 single gang sockets by 30cm and 60cm. The existing double socket is wired on a 4mm radial...
4K
